Omega 1000 Juice Extractor Logo
Posted on Apr 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My omega 1000 juicer won't turn on - I just bought it today.
Anonymous
Level 2:
Champion:
  • Expert 356 Answers
  • Posted on Apr 26, 2011
Anonymous
Expert
Level 2:
Champion:
Answers
356
Questions
0
Helped
125056
Points
478
Make sure it is assembled correctly and the latch arms snap shut completely
without any undue force. Also on the bottom of the juicer there should be a
reset button that might have tripped, just push it in. Other wise give Omega
a call.
3 Related Answers
Anonymous
  • Posted on Apr 26, 2008
SOURCE: how to replace latch arm for omega 1000 juicer?
Getting the old one out is the hardest part if the arm was broken off like mine. First locate the rectangular part where the arm attaches to the case. If the old arm, or most of it, is still attached, grasp it and pull firmly away from the case until you hear a click. Then, still pulling it away from the case, push it up toward the top of the case until it slides out. If the arm is broken off you have to pry it from the top until you hear the click. I used a small paring knife. Once you get it this far, wedge something like a toothpick behind it to keep it pulled away from the case. Then you need to push this push this part up. It is pretty tight so you might want to use some type of tool, like the blade of a flat screwdriver. Once you get the old one out, putting the new on in is just the reverse of taking the old one out.
Anonymous
  • 356 Answers
  • Posted on Feb 09, 2011
SOURCE: HI,
There are no instructions. Call Omega 1 800 633 33461
for advice. Also new arms on an older juicer may not
be an exact fit so you might have to do a little filing
down on the arm to get it to fit. You can remove the
4 screws on the bottom to separate the base and get
a clearer picture of what you have to do. Basically
you have to pry the base of the arm away and push
up to remove it. If you're not handy you may need
some help cause it gets tricky.
Anonymous
  • 57 Answers
  • Posted on Sep 03, 2011
SOURCE: my omega juicer won"t turn
Unscrew the bottom cover to expose the electrical cord. Check voltage if coming from the electrical cord by using a tester.If there is power, look for a a thermistor or a fuse and test if it is broken.
My omega juicer won"t turn
Hello, I just received my omega 8006 and it wont turn on
This juicer has a 15 year warranty which you can contact the manufacturer or retailer you bought it from depending on their return policies and exchange it.
http://www.omegajuicers.com/juicers/masticating-juicers.html
I have an Omega Juicer Model 1000. When I try to juice citrul fruit. The jicer may only turn for a second or two than stops. When I push down on the citrus it oftentimes will not operate.
If you're talking about the citrus attachment, there may be a
problem with the gearing inside. I have one for my Acme
which I don't use because of it's awkwardness and juice
splattering characteristics. Better off with an inexpensive
citrus juicer and leave the Omega to its carrots and apples.
1helpful
Just received replacement Latch arm for Omega 1000. Old one is removed. Can not put the new one. Top part does not slide in. Also noted the old part and new part look different. Base is longer in the...
Believe it can be done. You might have to file or shave the new arm a little then seat it as best
as possible and tap it in place with a screw driver and hammer. If you do manage to attach
the new arm and the fit is a little too snug when you latch down the cover, file the upper tip
of the arm for a little more tolerance. Also, believe it or not, a worn blade will produce less
vibration. There is a set screw bottom center. With the juicer fully assembled, unlock it,
turn it clockwise until feed chute contacts the shredder blade and back it off a half turn.
You now have the proper gap between the chute and blade.
Latch arm broken on my omega 1000 juicer. I have ordered one. How is it attached?
Omega can walk you through it, but have a file handy because the new latch
arms are not a perfect fit for the older juicers. You might want to remove the
4 screws on the bottom to separate the base for better access. If you have
a little mechanical ability it can be done, if not it could get tense.
1helpful
Juicer just stopped working
call or email omega url:omegajuicersdirect.com
1helpful
HI, I have omega 1000 juicer, and the latch arm was broken. I ordered the replacement latch arm online. I received my order today and there is no intruction how to replace it. I looked in omega 1000 manual...
I have an Omega juicer. I need to ajust it because it tremble too much Thank you
THIS IS A NON EJECTION PULP JUICER AND THEY
WILL VIBRATE LIKE MY ACME. BEST FOR HARD
PRODUCE LIKE CARROTS, APPLES, CELERY ETC.
FEED PRODUCE SLOW AND STEADY.
2answers
Right Arm of Omega Juicer Model 1000 broke off
CALL OMEGA 717 561 1105 THEY HAVE
THE LATCH ARMS. CHEAP. ASK THEM FOR
THERE ARE TO WAYS TO REPLACE THEM.
Top Omega Juicers Experts
john h
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Omega Juicer Expert? Answer questions, earn points and help others
