Have you had your coil tested and set the air gap between the flywheel and coil correctly? Also check the flywheel key for even the slightest damage. This can throw off the timing.
Terry
Try changing your carb jets,it sonds to me that they maybe old and worn or even just blocked
Thanks for the reply supermootch. Maybe I am wrong but, I was not aware these small carbs could be rejetted. The rebuild kit contains the float bowl gasket, float bowl nut whch has the idle metering screw, the main jet metering screw with the washer and the bowl valve with the new bowl valve seat. No jet included.
You may be on the right track with the carb issue though. The variance on the main jet and the idle just appear to be a bit wide. If I turn out either screw about 4-5 turns in the perspective modes, the engine should stall and it doesn't at times.
I had put this carb through its paces with the ultrasonic cleaner, and blew out all the orifices with forces air and sealed the welch plug with gasket sealer just incase. I did all the stuff I was supposed to do ....... that is why I am frustrasted with this now. It should be running like a champ and it is not.
Fixya is not very clear on how to start a new session so I ended up under the heading for the 5 HP Tecumseh where the engine I am currently working on is a 9HP.
