SOURCE: washing machine stopped working and smells like burt rubber
Sorry about that I did not notice the word "Belt" in the paragraph. The belt may be slipping. Even though it looks fine it may not be. You can normally tell if you're able to access the belt right after running it, turn off the washer and unplug it. Feel the belt or the idler pulley it's attached to. Quickly though because it may be very hot! If it is then chances are that you need a new belt. Overloading a washer from time to time can wear out the portion of the belt that contacts the pulley causing it to slip.
