There are many variations for a Norlake system
I assume the cooling coil hangs from the ceiling of the cooler and the condensing unit sits on the top?
The temperature is controlled by a control that is located in the condensing unit on the top of the cooler. This can be either;
\ a digital thermostat. You will need the progam key to get in
\mechanical thermostat. Adjust the dial setting
\ pressure stat. Adjust the dial setting
Probably best to get a technician in
