During the boot process you
will see on the screen to press a certain key to enter setup hope this
helps
Press and hold that key
during the boot up process to enter BIOS the scroll down to advanced bios
features press enter change your first boot device to cd,press escape then
press f10 to save to cmos to restart
(note after you have loaded
the operating system you must go back and change the first boot device to your
hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Yes I have already gone into the bios and changed the boot order to cd driver first, still get the same message.
windows might not be able to locate the hard drive test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
another possible reason is the cd/dvd drive
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Yes all the lead connections are fine. I can install windows xp or vista and they work fine, but even with a clean install on a new hard drive windows 7 still will not load. I have even tried 3 different new hard drives. I assume the windows 7 disc that I am using is ok as I can install windows 7 on my other core 2 duo PC's from the same disc. Maybe this motherboard and cpu combination isn't compatible for windows 7???
you will need a minimum of 2 GB of RAM to support windows 7 and if its 5yrs or older and asking for a driver it will not support w 7
Thanks for your help, that was my conclusion too. If I do figure out a way to get windows 7 to work on this set up I will post my findings.
good luck with that!!!
