Question about KitchenAid Batch Feed Garbage Disposal KBDS100T
Water won't drain - KitchenAid Batch Feed Garbage Disposal KBDS100T
  • KitchenAid Master
  • 5,391 Answers
Remove P-trap and clean tubular drain and p-trap
Copy following link to repair, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on May 22, 2013
Anonymous
SOURCE:
Tip
Cleaning and preserving a garbage disposal
Once a week or so turn the tap on at the sink and turn the disposer on. Then drop a cup of ice in the disposer. The ice will remove any grime and build up and the water will wash it all down the drain.
on Feb 20, 2015 | Garbage Disposals
Tip
Install a new garbage disposal
A garbage disposal can be either installed from scratch or instead of an older disposal.
First of all you need to shop for the disposal that best matches your needs.
For example you should consider whether a noisy disposal would be a problem in your household, what kind of plumbing you have, or if you have kids or not.
Here are some guidelines:
- Choose a motor suitable for your household. There are models with lower or higher horsepower, for smaller households with small amounts of food waste, or larger households with more food waste.
- Consider the features that you need. Like a quieter disposal, or one made of stainless steel, or one that connects to the dishwasher. There is a vast variety of options and prices.
- If you have kids you might want to consider getting a batch feed disposal rather than a continuous feed one. The batch feed disposal is a bit more expensive but it is also safer for kids, as it requires the use of a stopper prior operation. While the continuous feed disposal starts running when you flip the switch on and will continue running a bit also after you switch it off. This can be dangerous if someone drops utensils down the drain or sticks a hand inside the disposal.
- If your plumbing connects to a septic tank you need a disposal made for septic tanks.
After shopping for the right disposal, you need to get hold of these tools you'll be needing for the installation:
- Electrical cord
- Disposer wrench
- Hacksaw
- Screwdriver
- Water pump pliers
- Plumber's putty
- Safety supplies: goggles, dust mask, gloves
When you are ready, the first thing to do before installing the new disposal is to turn off power and make sure nobody turns it back on while you work.
Now you can proceed removing the old disposal.
If the old disposal is attached to a dishwasher, loosen and detach the dishwasher hose with a screwdriver.
Then with the wrench unscrew the slip-nut connecting the disposal to the "P" trap waste line, putting a bucket under the trap to catch any waste water sitting at the bottom of the trap.
Remove the old disposal with the screwdriver and take apart the rest of the mounting assembly, including the ring on the sink sleeve, the sink sleeve, the flange, the fiber gasket and the old plumber's putty. Make sure to clean well the sink, the sleeve, the flange and sink opening from old putty and grime before installing the new disposal.
You are now ready to wire your disposal, whether it came with appliance wires attached or if you need to attach them yourself following carefully the manufacturer's instructions (after unscrewing the cover plate beneath the disposal and then screwing it back in).
The next step is installing the drain flange and mounting ring by rolling some plumber's putty between your hands to form a snake about half inch thick and 10 inches long and applying it to the underside of the drain flange. Insert the flange into the drain hole and press down to attach it. You can then snap on the backup ring, fiber gasket and mounting ring.
Use a knife to cut away the extra plumber's putty that will have squeezed out around the flange.
At this point you can place the disposal into the mounting ring making sure that the disposal's outlet is facing the drain pipe connection, and tighten it until it stays in place.
Connect the P-trap, using the hacksaw to cut the discharge pipe to size if too long, and attach it to the outlet of the disposal. Make sure to connect it properly by reading carefully the manufacturer's instructions. If your disposal connects to the dishwasher attach the discharge tube to the disposal as well.
You can now turn the power back on and run cold water into the sink, turning on the disposal to make sure it's working and to check if there are any leaks, and running some food through the disposal to make sure it grinds and disposes properly.
You can also use this video to follow more visual instructions and help you in the process.
http://www.youtube.com/watch?v=DPaMgqnLW1M
Make sure to mantain your garbage disposal in good shape by avoiding grinding certain items like hard shells from shrimps, crabs or other shellfish, unpopped popcorn kernels and hard bones, by avoiding fibrous or starchy foods like banana peels, celery, potato peels, corn cobs, artichokes, fruit pits and hard seeds like avocados or peaches, onion skins and egg shells, as they create clogs and membranes that will ruin the disposal, and by cutting down big pieces of food into smaller pieces.
It is also best to run cold water while the disposal is on, keeping both water and disposer running for about a minute after the sink is cleared. Cold water helps push food down, avoid overheating of the system and unlike hot water, doesn't melt fat, that would re-solidify as a blockage further down the drain.
on Dec 23, 2013 | Garbage Disposals
Smelly garbage disposal
Patricia,
I would suggest putting some lemon juice in the disposal and let it sit for a short period of time and then run hot water down that drain while the disposal is running. Hope this helps!
May 21, 2015 | Garbage Disposals
Slow drain on garbage disposals side of sink
Try running ice cubes through it, it will make a lot of noise but that should clean it out. Please slowly run the cold water with the ice.
I do not like chemicals if they can be avoided. d
Nov 27, 2014 | Kenmore 1/3 hp Food Waste Disposer
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
Our super old insinkerator is spewing out water and gross dirt junk! What do I do?
It has to be clogged, try putting some Very hot water down the insinkerator. Remember if you have a dishwasher, it also usually uses the insikerator to drain. The Ice wont hurt the unit... so try both.
Jun 19, 2014 | In-Sink-Erator 1019E InSinkerator Batch...
Our new kenmore garbage disposal shoots the water up rather than sucking it down
Check the drain is not clogged.
Does sink opening have splash guard?
Check that plumbing is vented as required by code:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#slow
Gene h
Mar 23, 2014 | Kenmore 3/4 hp Food Waste Disposer
Kbds100t will not start
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Mar 25, 2012 | KitchenAid Batch Feed Garbage Disposal...
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
KitchenAid Batch Feed Garbage Disposal KBDS100T Logo
178 people viewed this question
Top KitchenAid Garbage Disposals Experts
Gene Haynes
markus
markus
Reno Smidt
Reno Smidt
Are you a KitchenAid Garbage Disposal Expert? Answer questions, earn points and help others
