Camping, Backpacking & Hiking Logo
Posted on Apr 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the coleman charger 1 spotlight model # 5347a718 need a battery
Anonymous
Level 3:
President:
  • Master 2,080 Answers
  • Posted on Apr 15, 2011
Anonymous
Master
Level 3:
President:
Answers
2080
Questions
Helped
927972
Points
6465
Yes it does.
See the product details at the following links:
http://www.amazon.co.uk/Coleman-Charger-One-Chargeable-Sportlight/dp/B0002JSZVU
http://www.coleman.com/coleman/parts/ProductImage2.asp?product_id=5347A718
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
Coleman 530 Lumens Spotlight needs a need battery FIFUTEC FP 1228, 12V 2.8Ah. Where can I find the right size?
Hi Mary, go to batteryspec.com. In the search box put in TR2.6-12 even though it's 2.6, it equates to 2.8 for our spotlights. The battery is around $20 with a 1 year warranty, and has the same specs (dimensions, terminal position) as ours.
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
1helpful
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
2helpful
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
1helpful
2answers
I have a vector 1 mil candlepower sport spotlight haven't charged it in a while,and doesn't seem to want to charge.Does this mean the battery pack is bad?
Unfortunately the batteries lose their ability to charge when not used for an extended period of time. The light is very simple to dismantle by removing the black rubber ring that holds the lens on and then removing the screws. I believe the following battery may be the replacement you need.
http://www.batteryspec.com/cgi-bin/cart.cgi?action=link&product=313
2helpful
Coleman Spotlight PML8000 lasts only a few minutes when charged
your battery is gone. chk with coleman for replacement
New wall Charger needed
Depends upon the model, but most use 12v 500Ma batteries w/ a barrel-pin connector.
You can buy one here, or search this site for your model:
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=69262&tid=16032
2answers
I need to get a cordless battery charger (old style, not lithium, will do) AND TWO old style batteries for my 18V Plus 1 RYOBI cordless recip saw. AND I need to get the manual. HELP! Sue Sweeney
Have you tried Ryobitools.com they have accessories and also a dealer locator that you can find them. If no luck let me know and give me the model number and I will try and track some down for you
Top Coleman Camping, Backpacking & Hiking Experts
Bob C
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
