SOURCE: Blender base gear knobs broke off
http://www.fixya.com/support/t509590-kitchenaid_ks85_coupling_drive
Reports the same problem and a couple of solutions.
SOURCE: looking for KitchenAid KPCB148SPM 1 Speed Blender blade assembly
Whirlpool online Canada has parts... I found mine there. http://www.whirlpoolparts.ca/repair_parts.php
I'm in Canada so it was easy for me, not sure if they ship outside or not... if you have trouble...email me at [email protected]
SOURCE: CA 4203 model #, Smoothie 700 Pro
Here's the parts order form:
http://www.focuselectrics.com/finditem.cfm?itemid=4287
-Tha Mp3 Doctor
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
SOURCE: KSB5600BO kitchenAid blender blades broke and l am
You don't need to replace the entire jar assembly. Have you tried to contact Kitchensid. They make high quality appliances and will probably send you new blades for $0.
Older KitchenAid blenders had a jar that was
made so the blade assembly could be removed for cleaning. On the newer models
the blender jar and the blade assembly are all one unit so you have to purchase
a new jar to get the blade assembly. All of this is dependent on which
model of blender you have.
We would be happy to help you. Please a give us
a call at 1-800-339-9297 we would be happy to help! One of our repair
technicians can talk you through the repair over the phone free of charge. On
the bottom of your blender is the model and serial numbers; have these handy
when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender
jar that fits your model in-stock we can order it and ship it to you. Please
contact us with any further questions. You can also email your model number or
questions to [email protected]
Sincerely,
Mendingshed.com Staff
