Question about Apex Computer Technology TX-381 Micro ATX Mid-Tower Case
I have a ECS A740GM-M Motherboard in an Asus TX-381 case. I can't get the 2 front usb ports to work. What am I not wiring up right?
    Scholar:
    New Friend:
  • 72 Answers
Make sure you are putting the front usb header connector on the proper USB pin connection on the motherboard. You should see nine pins in 2 rows together. Check the manual that came with the motherboard to find the correct pins location.
Posted on Apr 07, 2011
Anonymous
SOURCE:
How connecting the front panel header
Consult your manual all connections are covered in it on how to connect front header. If you havent got the manual you can download a copy here
http://eudownload.ecs.com.tw/dlfileecs/manual/mb/eng/k8/A740GM-M_20A_manual.pdf
Page 21 will show how to connect the usb and audio for the front
please vote for me if you found this info useful
Apr 17, 2011 | EliteGroup ECS A740GM-M Value Socket...
Where on the ecs a740gm m motherboard do i connect the front panel switches
You can download manual on this link:
I will appreciate your feedback and positive rating for thissolution.
Thank you.
Mar 13, 2011 | Computers & Internet
A740GM-M- DOES THE SERIAL NUMBER START WITH EA OR WITH V
For motherboard without parallel port: please check the farthest PCI slot from the center of the board, which is also the closest to the edge of the board. A white sticker with motherboard serial number is attached to the PCI slot.
It includes one letter +five numbers + one letter + eight numbers as follows.
http://www.ecs.com.tw/extra/productinfo/MB.htm
Jan 16, 2011 | EliteGroup ECS A740GM-M Value Socket...
Wie werden Power sw HDD led usw gesteckt
Hier findet man das buch ECS A740GM-M
Oct 23, 2010 | EliteGroup ECS A740GM-M Motherboard -...
Ecs A740GM-M - v1.0 will post ok but will not load op. system
Go into the BIOS and in the Boot order make sure the dvd is first, the hard disk is second and all the other options are disabled.
May 14, 2010 | EliteGroup ECS A740GM-M Motherboard -...
Front panel usb
Step 1: Decide weither you have one or two USB cables joined together, it should look like a 4 PIN header.
Step 2: Get your manual from ECS: http://www.ecs.com.tw/ECSWorldWide/Index.aspx?MenuID=0&LanID=9
Step 3: Install the 4 PIN header the right way +5V, - DATA, + DATA, GND on the motherboard, refer to the manual if you get stuck.
Oct 26, 2008 | EliteGroup ECS P4M800-M Socket...
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Apex Computer Technology TX-381 Micro ATX Mid-Tower Case Logo
164 people viewed this question
Top Apex Computer Technology Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Apex Computer Technology Computer and Internet Expert? Answer questions, earn points and help others
