Televison & Video Logo
Posted on Apr 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vchip reset? Inputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
Level 3:
Top Expert:
  • JVC Master 76,851 Answers
  • Posted on Apr 07, 2011
JVC Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003548
Points
237762
Hello
If a power interruption occured to your household power supply, V-Chip has to be resetted. To reset the V-Chip do the following.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To change the lock code, follow the steps below.
Press the MENU button
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/ Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
1helpful
How to I get the TV to show TV input. Show me everything else?
Hi EA.
Some of the answer will depend on the particular model of TV you have. Most flat panel TVs have multiple possible inputs, with some array of choices like HDMI 1, HDMI 2, Component, VGA, Cable that you can toggle through with your remote.
Most of them, in my experience, also will check first for inputs from the different components, and skip them if they don't show a video signal. In some cases, as was the case with my past Mitsubishi rear projection TV, each input channel had an option for either showing it or skipping it when cycling through inputs - that way if you just had Cable and a DVD player, you didn't have to cycle through 8 other inputs each time you switched.
If you're saying that a VGA input to the TV shows up fine on the screen, but other inputs don't, then that narrows it down and shows that the screen is working OK. I'm not completely clear then whether you have things plugged into other inputs like HDMI or component. if nothing else is plugged in, I'd guess the system detects no inputs from those ports and ignores them. If they are plugged in, but you don't see them, then you likely will need to activate or toggle those particular channels to be included amongst selections.
Hoping this helps, and Happy Holidays!
D
Sony STR-DG710
try to reset the tv throught the menu options, if that fails then the video inputs or video components in the tv needs repaired, if you have a "S Video" input you could use that or have the TV repaired.
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
HTS3541 - STARTING
Brand New? Send it back !
First go step by step through the instructions to make sure you hooked it up right.
Still not work? Return for exchange or refund!
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Vchip rest. Inputs won't show HDMI
Make sure you have a good hdmi cable, and make sure you have a signal. Try another HDMI slot, and see if that helps. If nothing works, unplug the HDMI inputs and turn the set off overnight. Then plug each HDMI plug in one at at time, and turn the device on. This helped in a couple of instances I know of.
Since I don't know the model you have, the following blog may or may not be helpful to you:
http://forums.logitech.com/t5/Harmony-Remotes/JVC-TV-input-problem/td-p/241569
Good luck, and hope this helps.
1helpful
2answers
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    My 52" Toshiba DLP just dropped an HDMI connection... There are two connectors on the back, both have worked fine until just now when one disappeared from the inputs menu on the screen.
    I'm not sure about your tv model as question post shows it is Toshiba 52HM84 that has one HDMI input at rear and you said 3 HDMI inputs in your tv.
    Please unplug tv from wall socket for minute or so to get it reset, replug back in, turn it On and check its HDMI inputs appear or not.
    Also check for Reset option in Menu for factory default settings that can also help you to get back disappeared HDMI inputs.
    If all that does not solve the issue then it seems hardware problem with HDMI circuit board and tv repairman is needed for visual check to get it fix.
    Hope these info will help you.
    Thanks.
    LG tv shows av inputs as black & white
    you need to plug all three colors in not just yellow
    red blue green need to be pluged in their respective colors
    2answers
    Technically challenged...need DVD to show on TV screen
    hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
    Top JVC Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
     Grubhead
    Grubhead
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
