The problem is that when the machine is turned on it does the normal sounding booting beep, after 3 seconds continues to a longer beep, then 3 secs no beep, then 3 secs beep, 3 secs no beep.... continously. Also no video working. Any ideas?
Try this reset procedure, but it sounds like an alarm situation.
How do I reset my Gorenje washing machine?
Upon start-up or during pause, the button backlight will flash; when the programme is started and in progress, it will be lit continuously. Use this button to turn the washing machine on and off, and to reset the washing programme. lighting Press the positions 7+10 and hold them for 3 seconds.
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display
Abnormality / Protection control
Abnormality
Judgement
Emergency operation
Primary location to verify
H00
No abnormality detected
Normal operation
H11
Indoor / Outdoor abnormal communica
tion
> 1 min after starting
operation
Indoor fan operation
only
• Internal / external cable connections
• Indoor / Outdoor PCB
H14
Indoor intake air temperature sensor
abnormality
Continue for 5 sec.
• Intake air temperature sensor (detec
tive or disconnected)
H15
Outdoor compressor temperature sensor
abnormality
Continue for 5 sec.
• Compressor temperature sensor
(detective or disconnected)
H16
Outdoor Current Transformer open cir
cuit
• Outdoor PCB
• IPM (Power transistor) module
H19
Indoor fan motor mechanism locked
7 times occurance
continuously
• Indoor PCB
• Fan motor
H23
Indoor heat exchanger temperature sen
sor abnormality
Continue for 5 sec.
O
(Cooling only)
• Heat exchanger temperature sensor
H24
sor 2 abnormality
Continue for 5 sec.
H27
Outdoor intake air temperature sensor
abnormality
Continue for 5 sec.
O
• Outdoor temperature sensor (detec
H28
Outdoor heat exchanger temperature
sensor abnormality
Continue for 5 sec.
O
• Outdoor heat exchanger temperature
sensor (detective or disconnected)
H30
Outdoor discharge air temperature sen
sor abnormality
Continue for 5 sec.
H33
Indoor / Outdoor wrong connection
• Indoor / Outdoor supply voltage
H38
Indoor / Outdoor mismatch (brand code)
H50
Ventilation motor abnormality
7 times occurance
continuously
• Indoor PCB
• Ventilation motor
H51
Nozzle lock abnormality
2 times occurance
continuously
• Nozzle
H52
Limit switch abnormality
• Indoor PCB
H97
Outdoor fan motor mechanism locked
2 times occurance
within 30 minutes
• Indoor PCB
• Fan motor
H98
Indoor high pressure protection
• Air filter dirty
• Air circulation short circuit
H99
Indoor heat exchanger anti-freezing pro
tection
• Insufficient refrigerant
• Air filter dirty
F11
Cooling / Heating cycle changeover
abnormality
4 times occurance
within 30 minutes
• 4-way valve
• V-coil
F90
PFC control
4 times occurance
within 10 minutes
• Voltage at PFC
F91
Refrigerantion cycle abnormality
2 times occurance
within 20 minutes
• No refrigerant
(3-way valve is closed)
F93
Compressor rotation failure
4 times occurance
within 20 minutes
• Compressor
F95
Cool high pressure protection
4 times occurance
within 20 minutes
• Outdoor refrigerant circuit
F96
IPM (power transistor) overheating pro
tection
4 times occurance
within 30 minutes
• Excess refrigerant
• Improper heat radiation
F97
Outdoor compressor overheating protec
tion
4 times occurance
within 10 minutes
• Compressor
F98
Total running current protection
3 times occurance
within 20 minutes
F99
Outdoor Direct Current (DC) peak detec
tion
7 times occurance
continuously
• Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
3 beeps 60 secs
