SOURCE: LG RZ 37LZ55 37 in HDTV LCD Screen Dead
hi there, the lights indicate that you have no video signal. do some test. ty
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
SOURCE: LG RZ-37LZ55 LCD TV no piture or sound. Set popped prior to probl
just repaired mine same problem
available on ebay ( lg power supply repair kit £17.99 does the job well
SOURCE: LG Plasma 42pc3d turns on, pops, then turns off
The first thing you should look into is the Z-SUS board, the one situated on the right side viewed from the rear. This board develops a high voltage during operation that might be the source of the popping sound. It is also responsible in refreshing the panel for proper picture display. The weird colors on your TV indicates a faulty Z-SUS board.
Note: Unplug the TV and wait for at least five minutes in order to allow the voltages to drain before you disconnect or reconnect any connector.
Feel free to update me of the result and your own findings.
SOURCE: there was a pop sound to the baCK OF THE TV AND NO
Y Sustainer problem. However, normally they have to change both Y Sus and Z Sus boards at the same time. If you lucky than it's just a fuse on the Y sustainer blown (the chance is very rare) otherwise the IPM (Intelligence Power Module) on the Y/X sustainer board is short. more then likely if you can get the IPM off of the board you will see that the components are shot, that is the popping noise you heard. shopjimmy.com has these boards some are cheap some are not...good luck
