Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
I had a similar issue. I had a water leak and had turned off the water. After that, things would freeze in the refrigerator section even when set to 40+ degrees. I finally turned off the switch to the ice maker and it went back to working normally. Apparently the ice-maker was overcompensating when it had no water supply
