Hi
Ld error indicates long drain and flashes when the
water level will not change even after the drain pump is on. To resolve this
please make sure that the drain hose is not clogged and the pump is working. To
gain access to the drain pump you can lay the machine on its front then remove
the drain hose and replace the pump if the impeller has gone bad. Please post a
comment if need more help.
Thanks
Rylee
