JBL Encounter Speakers Computer Speakers Logo
Posted on Mar 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a power problem with my JBL Encounter system. Since I played it very successfully on Saturday night with some marvellous music, it is no longer working. I have check the fuse in the plug and replaced it with no effect. The small green power light does not come on even pressing the on/off switch repeatedly, and there's no sound at all. What do I do please? best Lew Llewellyn
David Empson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 8 Answers
  • Posted on Nov 12, 2018
David Empson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
8
Questions
Helped
18200
Points
16
The same happened to me. The 5amp fuse soldered to the small circuit board in the power supply had blown. When replaced, I got my 18v AC output again, however when I plugged it back in to the speakers, the fuse blew again! Possibly the output amp has failed as the left and right speaker output pins are shorted.
Level 3:
Top Expert:
  • JBL Master 76,851 Answers
  • Posted on Mar 22, 2011
JBL Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986985
Points
237762
Hello
its power supply section has failed. you have to look into it for further trouble. Replacing fuse or line chord won't give you any result. you have to check wit whether the transformer faulure has occured or not. If it is fitted with a mains transformer, it will have a thermal fuse in it imbeded in between its primary and secondary windings placed inside the transformer and can be accessable if it is taken out. It is meant for to block the transformer woring, if it does overheats due to long run at high volume. Check from this and proceed. you must have a sound knoledge in electroncis and have a concept of soldering to do this work. OK.
2answers
Playing music through car audio system
You mean you wanna connect your bluetooth to your car stereo system JBL 99 toyota solora.
If yes then i am sorry because that's not possible.
Goodluck..
1helpful
How do I get my laptop to play music on my JBL Flip3 speaker? It finds each other on blue tooth and the music plays on my laptop but will not play on the speaker.
what operating system is laptop ?
is it windows vista ?
https://support.microsoft.com/en-us/help/933144/the-audio-output-is-not-automatically-routed-to-a-bluetooth-audio-devi
2answers
JBL Encounter Speakers Suddenly Lost Volume While Listening to Music.
Did you check the continuity of the line? If the end line (Jack) is pulled out several times over, the stress on the wires causes some wires to fray or breakaway. A pattern of increased resistance results and thus lower volume to the speakers. You may need to cut the end, replace the jacks.
What power supply do I need for a jbl encounter?
You need step down transformer to 18v ac 3.5A (the rectifiers are on the main board). The jbl model number is TA66 180350-82. The box also has a 5amp fuse soldered in
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel
    8 Ohm.
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
My JBL plays but it cuts the play back frequently like it plays and stops, plays and stops, plays and stops so on .Whats the problem. Please help
Until this is fixed, I would not use it or you may blow up a speaker... Make sure you check that you are using BALANCED audio interconnect cables, either XLR or TRS balanced cables AND that ALL interconnected equipment is poowered by the SAME receptacle... yes you have to run extension cords, but the pro's do it to avoid ground bounce damage to their equipment. Use ONLY three wire power cords.
I can not increase or decrease volume on my JBL encounter speaker system
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Have a JBL Encounter 2.1 Multi Media Speaker System need to find a power lead and speaker jack for it im resident in uk and need voltage requirements regards
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
