Question about LG 42LC2D 42 in. LCD HDTV
I have connected a Fiber Optic Cable from my LG 32" LED to my AV receiver but it does not work. How can I troubleshoot the problem? Does LG have some sort of testing/notification on the screen that the Fiber Cable is working/transmitting signal to AV Receiver? Thanks a lot. Dimay
6ya staff
SOURCE:
vinhson65
  • 257 Answers
SOURCE: Screen is black even though the green light is lit
Tv has power supply board inside defective. This board needs replaced.
Posted on Aug 18, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: The green light is lit on the TV but the screen is black
Could be a bad powersupply in the TV since you did unplug it and try to start it up it maybe you got a bad power unit inside these can be replaced for under $150. If you Tv is under warranty I would suggest you bring it in for a repair. Thanks for using Fixya.com please hit the ACCEPT button and give a good review thanks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
SOURCE: how can I use my lg lcd tv model m1994a for my ps3
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Posted on Nov 22, 2009
Testimonial: "ok!!! it is very much helpful...I solved my problem already using this steps...now I can play my ps3 games by my LG lcdtv 19 inches..."
Anonymous
  • 12 Answers
SOURCE: LG W2361V 23 Vga to HDMI Cable Not Working
You have a cable problem as no such thing as a VGA to HDMI cable exists.
HDMI is a didital signal and is thus not compatable with an anolog VGA signal. HDMI to DVI cables however do exist as both are digital signals.
Hope this helps.
Posted on May 28, 2010
khal75
  • 3 Answers
SOURCE: only av input is working LG 42LC7D TV
I may put money that some one did stole your internal cable from the power supply to the main board !
Don't be surprised they did it to me at LG company .
Posted on Nov 15, 2010
Want to connect fiber optic audio cable
If you have something providing an optical signal, you will need something such as a receiver that will accept and decode the optical signal. If you are able to make use of the HDMI instead of the optical audio channel, this would be the easiest bet. Otherwise you are looking at needing to get a receiver if you want to have more than 10W of stereo output, or if you simply wish to convert the optical signal into something the TV can understand, any fiber optic to analog converter, such as Amazon item B003OND0N4 (Search that string on Amazon)
Mar 28, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Bose Lifestyle AV 28 Media Center and PS 28 need Cable Pin In/Out
Are u talking about the fiber optic cable in and out put of the system all u new is to buy a optic cable if u need a converter from optic to RCA here is the site to buy one on amazon Digital Coaxial Optical to Analog RCA Audio Converter Fiber Optic Cable New 6_26_2014_11_28_58_pm.png
Nov 12, 2013 | Audio Players & Recorders
I just wanted to know how to hook up my lg 3d blue ray player. i'm not home so i can look at anything. I need to know how many HDMI cords I may need to plug in my tv, digital cable box, the a/v...
You can do this two ways.
Way #1 connect your cable box to your a/v receiver with one hdmi cable. Connect your blu ray player to your a/v receiver with a second hdmi cable. Lastly, connect a third hdmi cable from the a/v receiver to the television. (3 hdmi cables needed this way)
Way #2 connect your cable box to your television with one hdmi cable. Connect your blu ray player to your television with a second hdmi cable. Connect your a/v receiver to your television with a RCA/composite a/v cable or with a fiber optic cable. Connect your cable box to your a/v receiver with a fiber optic cable or RCA/composite a/v cable. Lastly connect your blu ray player to your a/v receiver with a fiber optic or RCA/composite a/v cable. This method takes 2 hdmi cables and three sets of fiber optic and or RCA/composite a/v cables.
Can't get more specific than that without having the a/v receiver's model number, type of cable box, and television model number. Hope this helps.
Jul 22, 2011 | Audio Players & Recorders
Not getting sound thru speakers only tv with hdmi cable connected do I need to connect Digital fiber optic cable too Also able to download owners manual for vsx1017txv
Receivers of this complexity require some patience. I believe the HDMI on this receiver is only for on screen display and video pass through. The audio needs to be separately connected. For digital audio you need to connect either via the digital audio coax or fiber optic input. I replaced my entire 1980s audio system with this unit and have been very happy. It's compact, and I feed it everything via a 35' fiber optic cable (under $20!) tied to a 3-way passive fiber switch (under $10) connected to my computer, a Tivo, and a DVD player. Sounds amazing (make sure to run set up to get the unit to perform with all of your speakers! -- I use an 8 speaker 7.1 surround set up).
Jun 17, 2010 | Pioneer VSX-1017TXV-K - iPod Ready, XM...
Yamaha rx-v365 plugged in the hdmi from cable box
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Connecting fiber optic cable with ''SC'' type connectors
No it should clip in, however you have the wrong connector on the end, usually these cables come adapters with them to suit you source or TV.
Get your self another cable with adapters, try eBay...!
Thanks
Oct 09, 2009 | Televison & Video
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
LG 42LC2D 42 in. LCD HDTV Logo
174 people viewed this question
Ekse
RONALD CARTER JR
