Question about Kenmore Refrigerators
My Kenmore 253 freezer/refridgerator has cold spots near the bottom of the refridgerator that freezes food even while the settings are low for the refridgerator. Vegetables freeze in the drawers below. The icemaker works but the water dispensors no longer works.
    New Friend:
Kenmore coldspotmodel106. water dripping on top shelf.
Posted on Mar 19, 2011
6ya staff
SOURCE:
I'm not sure which one I have, but purchased my approx. 2 yr. old Kenmore bottom freezer refrigerator from a trusted contractor doing some work in my home. I have a problem with the left produce bin......
Cold air from freezer blows into refrigerator compartment right behind that tray. Freezes stuff in that tray. Pizpoor design. Known issue. With GE refrigerators also of same design. That kenmore most likely was build by GE. GE/Kenmore deny the issue but thousands of posts online about it. No solution. Sorry. Good luck.
May 19, 2017 | Kenmore 62832 / 62834 / 62839 Bottom...
Kenmore 253 refrigerator/freezer won't stop running on any setting. The food in the top of the refrigerator would freeze unless I partially blocked the vent. I am wondering what the problem could be. i...
I have a Kenmore model 253 freezer/refridgerator upright model. I am getting cold spots in the refridgeration in and near the vegetable drawers on the bottom of the refridgerator. The icemaker works but the water dispensor has stopped working too.
Nov 28, 2010 | Refrigerators
Freezer coils completely frost (freeze) up--refridgerator warms
Sounds like the defrost timer or something in the defrost circuit. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) Find that number and we can go from there, Thanks, Sea Breeze
Jun 11, 2009 | Kenmore Refrigerators
Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
NOt keeping food cold
Good posibility that some thing is wrong with the defrost system. This is not as expensive to repair as a compressor. Is it worth it? The compressor and having it replaced and recharged will run much more than 250 a lot of the time or very close to it. Unplug it for a few hours with the freezer door open. Then plug it back in and see if it starts freezing again. This would tell you if it is something with the defrost cycle. The low motor noise may be the fan in the bottom of the unit. It would be good to know if the compressor is running or not.
Jan 28, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Refrigerators Logo
372 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
