Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <- ;-) ...
If you are victim of software counterfeit you may report that to this link especially if its something to do with microsoft products.
http://www.microsoft.com/howtotell/reports/report.aspx
And for other related software counterfeiting you may use the link below.
https://reporting.bsa.org/fraud/add.aspx
SOURCE: software counterfeiting,did not pass genuine windows validation
This sort of issue takes place usually after windows updates
Therefore the best solution is to uninstall the recent updates on your computer and restart again.
SOURCE: 'you may be a victim of software counterfeiting
OK, This is a notice from Microsoft. The validation tool thinks your Version is a counterfeit. It is not a virus, but is still a headache no less. It will not go away, we can't shut it off. The only way to fix is to reload with a valid code or call Microsoft to report it. I hope this helps :)
SOURCE: i'm a victim of software counterfeiting. How can
HI ^^
I HAVE FOR YOU SOME SOLUTIONS
INSTALL REVO UNINSTALLER ITS FREE
THAN CHOOSE YOUR SOFT THEN DELETE IT
DIRECT LINK TO DOWNLOAD REVO...
http://www.revouninstaller.com/download/revosetup.exe
OR DOWNLOAD YOUR UNINSTALLER 2008
Your Uninstaller! uninstaller software is the industry’s leading uninstaller software. It’s the world’s 1st smart Drag&Uninstall™ uninstaller software under the Windows platform, works on all Windows versions including Windows Vista/ XP/ 2000/ ME/ 98/ 95/ 2003. It’s as easy as using the recycle bin. Imagine! Just a drag-drop and the program you don’t want will disappear from your computer– as well as everything the unwanted program brings! Your Uninstaller! is a user-friendly way of removing unneeded applications on your computer. It can even remove some annoying spywares!
Download:
CODE
http://rapidshare.com/files/234603064/YourUninPRO.6.2.1347.rar
OR
CODE
http://www.uploading.com/files/NT01HZL0/YourUninPRO.6.2.1347.rar.html
IF ALL THIS DONT WORKS DOWNLOAD FILE SHREDDER
DIRECT LINK http://www.fileshredder.org/files/file_shredder_setup.exe
STILL HAVE MORE SOLUTION ^^
DOWNLOAD UNLOCKER
DIRECT LINK http://ccollomb.free.fr/unlocker/unlocker1.8.7.exe
PLZ DONT FORGET TO RATE IT FIXYA ^^
SOURCE: I am a victim of software counterfeiting
Try this site to download crack for genuine windows validation:
http://depositfiles.com/en/files/2951056
or if it really worst and your computer is lock by the program then you can re install your operating system then after you finished installing your new Operationf System then diable the Automatic Updates by accessing to your control panel then click Security Center then Automatic Updates and click diable or turn off Automatic Updates. In that way you can prevent your computer from downloading Updates from Microsoft and prevent downloads of other Windows validation program.
SOURCE: how can i remove software counterfeiting??
Try doing the following.
Note: With this method, you may be prompted to install WGA Notifications again which can still be unselected.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\
Windows NT\CurrentVersion\Winlogon\Notify
