Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Posted on Jun 05, 2017
Our Bosch Nexxt (wfm3200uc) finishes its complete cycle then starts filling with water. Turning the dial to off or any other location has no effect on the water flow. Turning the water off at the faucet (obviously) stops the flow. Setting the machine to drain and then to spin both achieve their goals. Turning the faucet back on after that does not result in water flowing into the machine. It will go through another whole cycle before the problem comes back. Any suggestions?
5 Related Answers
douglas smith
  • 1462 Answers
  • Posted on Apr 25, 2007
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Anonymous
  • 121 Answers
  • Posted on Sep 14, 2009
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Anonymous
  • 267 Answers
  • Posted on Oct 04, 2009
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see o circular lid there, turn it on anti-clockvise to open. All of the water blocked will come from there, be careful. Look carefully that there are some objects blocking the water draining. Then turn on the machine on draining programme, the plastic rotor should turn fastly when the machine is on. If it is not running, change the pump motor. If it is running, but machine is not draining again you can understand that there is an objeck stuck on the hose between drum and pump motor. Lay down the machine on its rear facade, you will see a large and black hose between drum and pump motor. When you remove it, you will see that there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
57 varieties
Karl Wright
  • 1653 Answers
  • Posted on Oct 23, 2009
SOURCE: Bosch Nexxt 700 won't drain water
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Anonymous
  • 3 Answers
  • Posted on Dec 01, 2009
SOURCE: Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
1helpful
3answers
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Bosch Washing Machine will not execute Wash cycle.
The brushes in the motor are worn out and need to be replaced or there is a problem with the belt or pulley. This is a fairly easy job and much cheaper than buying the motor. Access from the rear panel. If the belt is OK, remove it and then unbolt the motor, disconnect the wiring and remove the motor. If you are unfamiliar with where the brushes are located, then find someone with a little experience to help pop the old ones out and install the new ones.
5helpful
Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
2helpful
3answers
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
Cycles take an exceedingly long time to complete
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
Taking to long to wash
hi,sounds like its eiher taking too long to fill with water(tap not fully open) or the waste pipe is too low down.needs to go up and then down.but if too low the machine will just fill then empty constantly. neil
1helpful
2answers
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
