Master
- Posted on Mar 15, 2011
Re: I want to replace the oil pumpin a 1996 buick lasbre....
Removal:
Disconnect the negative battery cable.
- Remove the front cover from the engine.
- Remove the oil filter adapter, pressure regulator valve and spring.
- Remove the oil pump cover-to-front cover screws and the cover. Remove the inner and outer pump gears.
Installation:
Using petroleum jelly, pack the pump and assemble the gears in the housing.
- Tighten the oil pump cover-to-front cover screws to 97 inch lbs. (11 Nm).
- Install the pressure regulator spring and valve. Install the oil filter adapter.
- Install the front cover to the engine.
- Connect the negative battery cable.
