Your model has an auto damper=> 61005971 Auto Damper Click here for=> Auto Damper Test
The part is also called => Damper Control Assembly
We will need to do the Auto Damper Test first and if fails replace the auto damper. Let me know what you find. May appear hard to do but once the part is removed it becomes easy. Click Here=> Auto Damper Location Part number 8 in photo is the auto damper. They have a thermostat bulb that controls the air to fresh food section. If that thermostat goes bad the door may stick shut or full open causing these symptoms. If you need more help please ask and I would be happy to walk you through the process, Please Rate if this helps and ask if the damper is OK. In that case we may have a defrost problem restricting air flow,let me know and I will instuct you on how to solve that. These dampers fail an I feel it is the problem yet so many different things and appliances anything may be possible, I will help youi solve this either way! Thanks, Sea Breeze
