Problem description:
The laptop shuts off when AC power adapter is plugged in. The laptop
works fine on battery power but as soon as you connect it to AC adapter,
the laptop turns off.
Possible cause:
1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:
First of all, test the power adapter. Make sure the adapter outputs
correct voltage. It's possible that the output voltage is not correct
and the laptop shuts down to prevent the damage. Test your laptop with
another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most
likely it's the motherboard failure. Replace the motherboard.
