I broke mine too, but luckily I found an extra machine at a thrift store. The driver was missing (of course), but I cut the blades off (hacksaw, easy) and used the resulting shaft as a driver. It works well: better and tougher than the original! Though they are expensive, you can order a new set of blades and do the same thing with the blades you have now. -Paul
My old Cuisinart has this problem because the motor shaft and the corresponding socket on the cutter are worn. The shaft has jammed in the cutter. To un-jam it, stick a bar of wood behind one blade of the cutter (I use the wood handle of my dough whisk) and give it a light, sharp tap with a hammer. Check after every tap to see if it is loose, if not do it again. You want to tap against the back side of the cutter, not the cutting edge side. The socket on your cutter may be cracked, allowing it to open up and slip (and jam) under the stress of cutting. You'll probably need a new one. If the motor shaft is also worn, that can also be replaced. The new part is about $10. I got a few more months of life from my cutter by reinforcing the inner socket with a thin plastic tube from the barrel of a syringe.
Sue, I have one the same model number and I cannot use it since the top is broken. I can send picture of the blades if you are interested. Please email me at [email protected].
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us
toll-free at 1-800-798-7398. Hours are Monday through Saturday from
9:00am to 6:00pm Eastern Standard Time.
