To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming
from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few
seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you
are programming, the lights should flash after ever button push. After
all four codes (buttons) are learned, the unit will exit code learning
mode. If not, turn off key and close hood. Hope this helps......BUZZ
How do i set the time on the remote
