The default password is 0000. If you manually assigned a 4-digit password, and forgot it, you will need to follow the password recall procedure.
If you forget the password:
You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power) and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure.
To enter the password recall procedure:
Press and hold Right for 5 seconds. The projector will display a coded number on the screen. In this case your recovery code is: 22135 - 15520 - 7440 - 10130
Your recovery password is: 7771
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Thank you for choosing Fixya.com!
please help me with my benq projector mp610 the recovery code is: 20416-14218-6789-8827...tnks in advance frm [email protected]
i lost my BenQ password, the decode number is 20915- 13962-6789-8574. PLease help, thanks.
I lost my BenQ password, the decode number is 20915- 13962-6789-8574. PLease help, thanks.
Hi,I have a Benq PB240 projector that I have forgotten the password then I need the code to unlock it. The recovery code for it is 21344 13898 6789 8507 I hope you can help me.
Hi,I have a Benq mp610 projector that I have forgotten the password for so need the code to unlock it. The recovery code for it is 20970 - 13770 - 6789 - 8380
izzeldin
Only BenQ has the unlock codes for the projector.
Your best bet is to contact benq here..
http://www.benq.us/page/?pageid=902
Explain the issue your having with the lost password, fill in the information required, and they will contact you back with the unlock code.
Other then that. If your familiar with the internal components of electronics.
You could open the projector, locate the coin cell battery. And remove it. Let it sit that way overnight, and it should blank out the password.
That will void any warranty you have though, so i strongly recommend contacting Benq Support at the link i provided..
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
To recover the code that will allow you to obtain the PIN you set into memory press and hold right for 5 seconds the projector will display a coded number on the screen then you MUST contact the BenQ support center for help decode that number and unlock the projector.
You may need proof of purchase. Below you will find a courtesy link to the BenQ support page with contact information.
Sorry to say that you need to contact local Benq service center to get the password reset. You need to provide the purchase documents for the projector. After document verification, your projector will be unlocked with the password provided.
Hope this helps.
Shane
CAUTION: Once a password has been set, the projector cannot be used unless the correct
password is entered every time the projector is started.
Contact
info for Canada technical support is
(866) 600-2367. Just select the exact region of your location and in that
select "service and support". This will give you exact contact info of the
local benq service provider in your area.
recall procedure.
Press and hold Right> button for 5 seconds. The projector will display a coded number on the
screen. Seek help from the local BenQ service center to decode the number. You may be
required to provide proof of purchase documentation to verify that you are an authorized
user of the projector.
Give the exact coded number to the benq service center.They will insert your provided coded number in there system software and this will give them the exact password,which will unlock your benq projector.This password can only be decoded by benq system software unit.
Your recovery code is 22135 - 15520 - 7440 - 10130.You will have to provide this exact number so the benq service executive can decode it and retrieve the exact password for your benq projector.
To locate the benq service provider in your area.Please click the link below:---
http://www.benq.com/
The password which you receive is free from the service center. You just have
to give the exact recovery code.
This should help. Thanks. Helpmech.
The code can be recovered from the software only.The software has the code reading chip.With that only password can be retrieved.Still as you provide the recovery code,they should provide you the exact password.-------Keep updated.Thanks.Helpmech.
Press the power button at the top of your Benq projector remote to turn off your projector. Locate, press and hold the stanby button on the projector remote, wait for five seconds and then repress the power button to power up the projector, your projector should be unlock.
Hiya,I've lost the password for my BENQ MP610 Projector. The onscreen instructions give the the code 22135 - 15520 - 7440 -10130.
This lady from your site has answered the question for a few other people as each decode number is individual.
If you can't answer can you please pass me onto her.
Here she is...http://www.fixya.com/users/marrie
I have a Benq mp610 projector that my dad got from a car boot sale thinking it was a video recorder.
It has a password on it that needs to be decoded.
I have no proof of purchase so can't contact the manufacturers.
The decode number is 22135 - 15520 - 7440 -10130
I have a Benq Mp610 projector that my dad got second hand from a boot sale so therefore I have no documentation. It has a password on it which renders it useeles.
The numbers to decode it are 22135 - 15520 - 7440 - 10130
previous experts on this site have told me the master code is either 9001 or 9000 but this havn't worked.
I need an someone who has experiance with projectors/BENQ to help me sort this out.
Thank you.
Thats the problem,the password was on a note with the projector but we lost that on the way home so have no proof of purchase.
You have Benq experts on this site (Marrie) that have provided the unlock codes for other people on many an occasion.
Is it possible to ask one of them?
t3trt gregr
Hello,I have a Benq mp610 projector with a pasword lock on it. We have lost the note the password was written down on.
The decode to unlock it is 22135 - 15520 - 7440 - 10130
We can't contact Benq as we don't have any documentation as it was brought from a car boot sale.
The expert Marrie on this site has provided the delocking codes to a number of people on here so it's an expert like her i'm after,thank you.
Hi there's still none who can answer my question as my benq mp610 has a password locking it which was lost.
I can't contact the manufacturers and have no proof of purchase as the projector loks a few years old.
the decode number it puts up to unlock it is 22135-15520-7440-10130
Other people on your site have provided the answer for other people as I need the code to unlock it.thanks.
I have a Benq mp610 projector that I have forgotten the password for so need the code to unlock it. The recovery code for it is 22135 - 15520 - 7440 - 10130
I've opened the projector up and canot locate a coin cel battery which I believed may have reset the password.
The projector is 2nd hand so I can't contact Benq.
Thanks
yep
thank u so much;)
thank you:)
