Hi my sansa media player wont work it is not writing my songs on the ipod. it writes a couple song sometime but not the ones i tell it to so i dont know what to do can u please help me!!!
my sansa is not turning on just a blur ring light is turning around iam unable to see anything. and it does not get format .iam unable to write videos in it. and unable to record songs in it
You can't post conmments that contain an email address.
Hey there, http://www.bespokesongs.com is the most touching gift you could ever give
or receive and is a truly personal way to express how much
someone one means to you. Your song will be created by critically acclaimed singer-songwriter Lotte Mullan whose music has
featured in films by Ridley Scott, the LOVEFILM ad and BBC Radio 2. Home
Hi, i was trying to delete some songs, which i did and now it won't come on. you think i made it stop working. i've been trying to delete songs for about and hour or two.it's doing nothing now. i'll wait about an hour before i try to turn it on again.
Same problem delete a couple of songs up to 6 mg or 10 whatever then allow to refresh then download your songs back in the music file. the sansa needs some memory to know it has the sdcard in it...
Go to my computer scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works Start over put new songs on it
Are you running the most current version of iTunes? If not try upgrading. After that, try seeing if there is an firmware upgrade. If there is, try upgrading that too. Then try reuploading songs. If it is still not working, it might be damaged or just not working anymore. Only use Itunes when uploading songs to ipod regardless of type.
You may need to update the firmware on the device. The data base on the device could be corrupt. Follow the instructions in the given link: Updating Sansa Clip's Firmware
It depends on how many songs you are trying to transfer. I wouldn't try transferring more than 10 at a time - should take 2-3 minutes max. 200 songs is going to take at least an hour on some players, and you are prone to run into problems.
Do you use Napster by any chance? Some music services actually remove songs after the subscription expires, or if you haven't synced your Sansa to that service within 30 days. Convert all songs to mp3 format, and you will not have that format.
Also, your DB could have become corrupt. A firmware upgrade usually resolves it.
I would wait for the writing message to go away before disconnecting the player - this is the standard message it will give you when you are transferring songs to the player. If it still says writing after 5 minutes (this is assuming you are not trying to load more than 20 songs at once), then you might have a real problem.
Make sure the files you are trying to load do not have DRM encryption on them, and also make sure they are in mp3 or wma format.
If you have Windows Media Player 11:
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa
shaker. This is the only way to load songs from your cds MWA will not
work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
it might be because the media player try using a diferent media player or buy an sd card and put music in it it reads it just fine and you can use the internal memory for videos only hope it helps.
I restored settings to default factory settings and has been working and not skipping the songs. Restoring to factory settings does not delete any of your data/songs
