Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Testimonial: "That absolutely worked, thank you so much! I could never have figured that out."
P.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
span.Apple-tab-span {white-space:pre}
Follow the steps below to set the date display style, current date and time. 1. Rotate the mode dial to the Wrench and turn your ViviCam 5385 on by pressing the POWER button. 2. Press right arrow to select the CUSTOM menu. 3. Use down arrow to select DATE & TIME, then press the "ok" button. You may press the left or right arrow to switch the date types. 4. Press the left / right buttons to select Year, Month, Day and Time fields.
5. Press the "ok" button after all fields are set.
SOURCE: vivitar vivicam 5385 digital camera
wont power on even with new batteries please email m e with suggestions www.aol.com
SOURCE: need a usb cable for my vivicam 5385 digital camera
Usually I find Walmart the best place to get items like this, especially if you can readily get to a Walmart Supercenter.
Also, you might find it online at www.pricegrabber.com to get a good price. Take care, & good luck!
