Re: How to remove doors on samsung side by side...
We always unbolt the top hindge cover,and unbolt the hinge and lift the door off of the bottom hinge.Hope this helps,if so give us a 4 thumbs up. THANKS
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
I'm in the same boat. I'm sitting here withe freezer door unscrewed and I have no idea how to disconnect the water line going up the side of the freezer door. I guess I'm going to rip it. I was going to give this hunk of **** to goodwill since the freezer still somewhat worked but now this, screw it. David
this isnt an electric heater in between the doors its a hot gas loop. there is a motor behind the refrig that cools the comp and condenser coils this fan is either not working or something has jammed it up. just pull the refig away from the wall remove the compartmnet cover and check that fan out good luck peyton
take plastic covers off top hinge remove 3 screws pick door up off bottom hinge do not remove bottom hinge,both doors remove the same left side u have to disconnect the water line.
