Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips. If your refrigerator is running but warm, then… Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
the freezer back wall need to be open and check the heat element and the thermostat , also make sure the fan is working in the freezer. if the frost on the coils are not even then it is seald system that is bad news, but if it is just frozen defrost it with hair dryer and check the elements i told you to check
Hi: When this happens it means that there is frost built up in the back of the refrigerator. You are having an issue with the defrost heater or the defrost timer. There is an off chance the refrigerator's freezer is over packed with food and there is no circulation. If you're handy empty the fridge and take a hair dryer to the back wall to melt away the frost from behind. You will have to remove the back metal wall. Look at the heater. It will be at the bottom of the freezer behind the back wall. A glass tube with a wire coil running through it. If the coil is broken, replace it. If not you will be looking at a defrost timer. Sometimes on a circuit board. Searspartsdirect will have the parts and schematics. I hope this helps, Jeff
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way. refrigerators release some of their heat between the doors to prevent condensation, but if it very hot then the machine is not releasing enough heat from its coils under the machine.
