Question about Toshiba Tecra M5-S4332 Notebook Pc
Please can you urgently tell me how to start my computer in safemode it is a techra M5
  • 242 Answers
When the bios screen comes on while the computer is starting begin tapping F8. Eventually a black screen with white text comes up, select safe mode.
Hop that helps
Ray
Posted on Mar 03, 2011
    New Friend:
  • 65 Answers
Restart the computer, then when you see the toshiba screen, start tapping that f8 key. It should give you a screen to choose modes. If that doesn't work, only press it once during or after the toshiba screen.
Please rate if this helps!
Testimonial: "Thank you so much aaldrich29 - worked a treat -really appreciate it!"
6ya staff
SOURCE:
On 5 sec after off laptops
You could try to start the computer in safe mode, to see if this is driver issue. When starting computer, press down F8 and select safe mode startup. If monitor works in safemode, try to reinstall display driver.
Also you could check with external monitor, to isolate where the issue is related to. If external monitor works fine, it might be HW problem with your laptop monitor.
May 01, 2014 | Dell Vostro 1015 Laptop
My laptop has power but wont boot...please help
hi,
Try to boot you computer to safemode, turn off computer then turn it back on then keep on tapping F8, then choose safemode, if youre able to boot to safemode, do system restore going back to the time that its properly working, click start > all programs > accesories> system tools > system restore then pick a date when you think that its properly working..
If its not able to boot to safemode, you will need to reinstall the operating system using the recovery disc that came with the computer.
Hope this will help... Please rate...
Jan 20, 2011 | Acer Computers & Internet
Ok after my computer boots up and i log in the icons come up and like a minute later it all freezes i cant do anything please help i dont have any computer experience
Try accessing safemode or safemode with networking,
if you're able to access safemode or safemode with networking without having the same problem disable start up items and services of your computer and if your able to access safemode that only means that one of the software in your start up item is causing the problem and if you're not able to access it run the hardware diagnostic of your computer ( if that's a dell you'll need to access it in f12 ) if the test passed without any errors you'll need to reinstall your operating system but if it fails then it give you an error contact tech support of dell give them error they tell you what you need to replace. By the way if your just gonna end up reinstalling your operating system, BACK UP your files first before doing so.
Feb 12, 2010 | Dell Vostro 1500 Notebook
My 915-m5 mb starts but have no video. No sound except for fans and hd are noted, but no signal video is seen in monitor. Please answer to joitod@coqui.net at your earliest convenience. Thanks
do you get a single beep about 2 to 5 seconds after the system is powered up..? If no, then your mainboard IS NOT working. The fans and hard drives will still spin up even if the mainboard is not booting. You need to listen for that single beep as this tells you that the boards POST (power on self test) has completed and all is well. If it does not beep, then you have a mainboard issue. Reply to this and tell us if you hear this beep or not..
Jan 14, 2010 | EliteGroup 915-M5 Motherboard
Safe mode
turn off the PC buy holding down the power buttom. turn the unit back on after 10 mins.
if a menu pops up select "start windows normally"
if your using windows 98 please upgrade you system to XP or Vista
Jan 23, 2009 | E-Machines eMachines Desktop PC
Start menu keeps flashing on/off,dell laptop.
Hi rayo49,
Try booting in safemode. restart your computer and tap F8 repeatedly at boot up. select safemode and select windows xp.
If it does the same thing in safemode check the windows key on your keyboard. it may be stuck.
If it does not. try using system restore. start>all programs> accessories> system tools> system restore. rsetore computer to a few days back or before the problem begun
Oct 11, 2008 | Dell Inspiron 2650 Notebook
Xp/home
hey drup
have you tried going into safemode and in safemode, try to do system restore.
you or someone may have deleted an important file... thats why your computer wont start up normally.
please try safemode and post what happens. thanks
Apr 22, 2008 | Computers & Internet
A locked bios password on techra m5
hello guys
For the password to be removed the battery will not remove the password the only way to remove it is by hardware on this laptop or you can contact Toshiba with the challenge code.
1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another:
Ctrl, Tab, Ctrl, Enter
The computer's response should be:
PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code=
if you have any questions please email me or check my forum www.biosmasters.com/Forum1/index.php
Mar 25, 2008 | Toshiba Tecra M5-S433 Notebook
Toshiba Tecra M5-S4332 Notebook Pc Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
