SOURCE: Maytag Neptune mah7500aww adding water to wash cycle problem
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Pl rate if helped.............
SOURCE: I have Maytag Neptune Washer.My touch pad
replace the user interface or touchpad control that is the control panel on your unit the whit part
SOURCE: I have a Maytag Neptune top load washer touch
I no longer need a solution. My son took the lock off and put it back on, and the machine started working again.
Thanks you so much.
SOURCE: Why does my Maytag Neptune Washing machine smell
you have mold built up around the door boot. you need to buy a package of a product called AFRESH (3 tablets in it). follow the directions on the package. use one a month for maintenance on this machine. also, make sure you do one or two hot washes per month to keep the hoses cleaned from build up of soap and or fabric softener. leave the door open a little bit after each load.
