Installing a video card is relatively easy if you follow these steps.
1. Open the case so you can see the motherboard.
2. If the computer has a video card in the long yellow slot, remove it carefully at this time. Unscrew the card from the back of the case using a philips head screwdriver. Be sure to press the small while lever at the back of the yellow slot to release the video card. If the existing video card has any power plugs connected to it, be sure to unplug them as well.
3. Once the old card has been removed, gently press your new video card into the slot. You should hear a slight click signifying that the small white level has locked the card into place.
4. Screw the new video card to the back part of the case to secure the card from any movement.
5. Attach any power cables that the video card may need.
6. Close case and turn on the computer.
7. Once the computer has booted, be sure to install your new video card drivers from the CD that came with the card or from nvidia's website.
It will not fit you do not have a PCI Express 2.0 x16 slot on your motherboard.
Http://www.ehow.com/video_4445576_pci-express-video-cards.html
Here is a cool video explaining how to install a pci express video card.
It's relatively simple. good luck!
Regards,
~Will
Insert the GTS 450 in the long yellow slot (the one below the short yellow slot). Connect the corresponding 6pin power cable from the power supply. Make sure the card is screwed in to the case.
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers,
SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware's manufacturer - No need to waste hours upon hours every week searching the Internet for the latest driver files. You have better things to do than a driver scavenger hunt!
You could try either of these to find and fix any driver issue
