Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
below is a link to a video that explains how to access and clean the drain motor.
http://www.appliancerepairlesson.com/2011/01/21/washer-not-draining-repair-bosch-maual-door-release/
HI I HAVE HAD DIFFERENT LIGHTS AT OTHER TIMES FLASHING TOO RESET BOSCH wae18060au/05 AND MAYBE OTHERS
1.TURN KNOB TO OFF POSITION
2. HOLD IN BOTH START AND MIDDLE BUTTON MINE IS (RINCE PLUS )
3.TURN KNOB TO THE LEFT WHICH SHOULD BE DELICATE WASH COLD WHILE STILL HOLDING IN BUTTONS
4.WASH BUTTON SHOULD LIGHT UP TURN KNOB TO OFF AND THEN TURN BACK ON SHOULD BE RIGHT TO GO ;)
