Firstly, make sure that your kindle is fully charged. Then hold the power switch for 7 seconds. After the light blinks three times, release it. If this does not unfreeze your kindle, hold the power switch for 15 seconds. This should restart your kindle. If neither of these solutions work try contacting amazon kindle support, as they can remotely connec tto your kindle and see what is wrong.
Cheers
Sine Wave
Kindle is jammed it means there is the issue with the operating system or might be some files of the device are corrupted. You should try to reset the kindle device. for more, you can ask amazon for the Kindle Support Kindle Technical Support Registration 877 690 9305
SOURCE: Kindle will not recharge from
Hi, you can use the link below for guide lines...
amazon.com/gp/help/customer/display.html?nodeId=200169400
amazon.com/gp/help/customer/display.html?ie=UTF8&nodeId=200510540
portatronics.com/index.php?cat=c144_Kindle-1.html&XTCsid=dloooo6s8vmmr2lu0q1ihvolj3
Hope it helped...
Trying to connect to Wi-Fi I put in the code and it just states there is an authentication problem.
