Scroll Lock Key
nearest air target
Alt + Scroll Lock Key
center-of-view air target
Shift + Insert Key
next air target
Shift + Home Key
previous air target
Shift + Scroll Lock Key
nearest ground target
Ctrl + Num Lock Key
center-of-view surface target
Shift + End Key
next surface target
Shift + Delete Key
previous surface target
MISSION EDITOR
Ctrl + N Key
create a new mission
Ctrl + O Key
open an existing mission
Ctrl + S Key
save the active mission to disk
Ctrl + Shift + S Key
save the mission under another name
Esc Key
delete the current selection on the map
Delete Key
Ctrl + Shift + C Key
assign the active mission to a class and protect it with a password
Ctrl + Shift + D Key
declassify the active mission
Ctrl + H Key
hide or show specific objects on the map
Ctrl + 1 Key
return the map to the default magnification level around the crimean peninsula
Ctrl + + Key
magnify the map by a factor of 2
Ctrl + - Key
scale the map down by a factor of 2
Ctrl + O Key
take the view down to a very close level
Ctrl + V Key
magnify the map to a regional view centered on the selected object
Ctrl + B Key
view and edit the mission briefing
Ctrl + D Key
view a debriefing when a saved mission is loaded
Ctrl + F Key
start the current mission
Ctrl + N Key
begin a network multiplayer session
Ctrl + M Key
chat with other players during a multiplayer session
Ctrl + R Key
start the mission and record a video sequence
Ctrl + P Key
play back the last recorded video sequence
Ctrl + V Key
start the video sequence and enable its editing
Ctrl + Shift + F Key
specify failures that may happen to your aircraft
Ctrl + Shift + W Key
specify meteorological conditions
Ctrl + Shift + E Key
open encyclopedia
Ctrl + Shift + O Key
open options screen
F1 Key
help
F2 Key
keyboard command list
