SOURCE: problem with child lock activated on bosch logixx
Most, but not all have a manual opening device located somewhere near the strainer or any other access opening on the Machine.
Just for furture reference, if you press and hold the start button for five seconds the "feature" should disable... hope this helps
SOURCE: bosch logixx 1400 express washing machine spin is
The 03 error code is the drain. Disconnect the drain hoses
and check for blockages. If no blockage "time" the drain interval. If
it's more than 6 minutes it's the pump. Also make sure you're using the
correct
type of soap so the ball check valve on the bottom of the outer drum
isn't
getting fouled with excessive suds. Also disconnect the drain hose from
your
house plumbing and let it free flow on it's own. This will tell you if
the
block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
SOURCE: Can I get a user
Hi.
Below a user manual for Logixx 1400. There are different models corresponding to Logixx 1400, if the manual below does not apply, please ask a new question providing full model number as on service tag.
Bosch - Bosch Logixx Sensitive Automatic washing machine
