Question about Remote Starter with Keyless Entry
Car starts all by it self with out notice - Remote Starter with Keyless Entry
    New Friend:
It is set to automatic on....reprogram to off
Posted on Jun 06, 2011
Anonymous
SOURCE:
Not starting
you have blocked the vent switch up you must not run and engine while filling up with petrol. can unblock its self around 3 days or so depends on how much petrol went up it.
Mar 07, 2014 | 2001 Volkswagen Polo Car Cover...
My bmw 318 diesel wont start when the engine is cold i have replaced the heater plugs and control unit bu i noticed this morning that the engine manage managment light does not come on straight away and...
i was having the same problem...then i got a diesel treatment its call diptaine mix it in with your fuel and let it do it work the next morning my car started no problem
Oct 06, 2012 | 2004 BMW 3 Series
2003 chevy malibu rough idle
check your timing, fuel filters, check your points, or spark plugs is your rotor cap where it's suppose to be and is it good? i've always disconnected the battery and it seems to reprogram it's self. see if that works
Aug 19, 2012 | 2003 Chevrolet Malibu
When i started my truck, the transission did not engage and I also noticed that fluid leaked.
May just need tighten up, they do work them self lose on occasions, If all is tight might want to replace your transmission pan gasket. good luck to you.
Mar 27, 2011 | Ford Ranger Cars & Trucks
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
Stuck on self check failed
i tried changing drives and then i put in a different dvd.
that worked.
Feb 11, 2009 | Panasonic DMR-ES35VS
Big sound in trial of starting maxima 1996
if its not starting then its something else than a water pump verify that its your water pump first before you take anything off because it will give you a headache if its something else.
Jan 19, 2009 | 1996 Nissan Maxima
Self cleaning caused interior glass to crack
hi there,
this is called thermal breakage. basically, when the mfg. makes the glass, they either don't cook it long enough or let it harden long enough during manufacturing. remember, the glass is supposed to withstand over 1200 degrees, which is temperature during self cleaning. have a technician replace the door glass, as warranty should cover this.
thanks
Sep 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Fuel pump relay & fuel pump
when you turn the key on the pump should run to purge the system . so now you have fuel pressure for starting. this stage lasts about 10 seconds then the fuel pump doesnt turn on again till the computer see's oil pressure then turns the pump on. if the inertia switch has been activated it wont send the first amount of fuel.
Jul 26, 2008 | 1996 Ford F150 Regular Cab
Remote Starter with Keyless Entry Logo
46 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
Larry Tezekjian
Larry Tezekjian
Matthew Boulden
SSN-MM3
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
