Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Feb 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washer stains my clothes. it looks like grease stains on delicate fabrics. plse advise. I checked many times and dont know where it is coming from. agnes
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Feb 26, 2011
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033434
Points
35540
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa
White clothes come out stained
AT LEAST YEARLY YOU HAVE TO CLEAN WASHER ORTHER VICE STAINED COMING NORMALLY.. YOU HAVE TO CLEAN WITH OXSY CLEANE LIKE BORAX,CLOREX,,
Kenmore 70 series, leaves browb lines on clothes. is there cleaning procedure for the washer?
It could be coming from your fabric softner. I know when I use liquid fabric softner I get oily looking stains on clothes. I no longer use liquid softner. I also use Dawn dish soap in my washer. I use Dawn instead of any other stain removers. Dawn dish soap works on everything.
1helpful
Maytag washer LAT9334AAM aprox 14 yrs old. Have
Are you using a liquid fabric softener ? If so , try using dryer sheets instead . Maytag is known for making liquid softener look like grease on clothes . After switching for a while , and still grease looking stains , then it is possible for the water to be getting into the transmission and pushing the grease up into the tub . Rare , but happens . Time for another machine if that happens .
Rust stains on clothing
Cleaned lint out of the dryer internal air ducts.
Replaced the upper and lower drum seals.
1helpful
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
1helpful
Clear greasy stains appearing on clothes from brand new LG front loading washer
the grease i'm sure would be coming from the machine. look at the water solenoids, detergent dispenser, dispenser solenoids, everything with rubber hoses.
they do put a clear grease just to insert the hose easier in the plant. and if it was not removed during QC, then it would come out now as you uses it.
tnx 4 using fixya,
drcool
1helpful
4answers
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
4answers
Stained clothes
there no grease in ft loading washer possible cause fabric softner
2answers
Washer and / or dryer causing stains
Better check the fabric softener dispenser because if at any time someone added undiluted softener it gum up and release at a later time especially on whites . The drum of dryer may have rust or paint missing inside or on the back , check this out . If drum is missing paint and wet clothing sets on that area long enough they will create rust .
1helpful
2answers
Grease spots and stains
Yes you can. Remember a front loader has no gearbox so no oil is coming from there? fabric conditioner, washing powder,and oils from our bodys can build up on the tub walls. All it needs is a good flush out. You can use dishwashing powder. Run it through with no clothes in you washing machine on a hot wash or a wash and hold a couple of times to flush it out. NZL
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
