If you go to this site they will show you the disassembly of your unit as well as provide parts info.
Search Over 2 1 Million Appliance Parts
SOURCE: dishwasher detergent left in dispenser
there is no solution for it because of its design. i have same GE and same problem. It is happening because top rack is right front of the detergent cup and it is not opening 180 degree while it is washing. it opens only 15 or 20 degree and water just doesnt get in there as much as suppose to be because only water can get in there from the bottom sprayer arm because detergent cup lid is not allowing water to get in the cup from middle and top sprayer like any other dishwasher! i called them so many times and they are just jerks! they blame anyting about my house but their dishwasher. their tec. showed up 4 times and they just keep blaming hot water temrature etc. water temprature doesnt matter if water cant get in the detergent cup, right? but they dont want to admit that because they are like programed robots to give you same answers and just blame you but GE dishwasher. please fill out complain form with Consumer Complaint Department. you should be able to find their address and web site on the internet. Please do so, maybe we can get refund or replacement or something. Never ever buy GE again. Just get a Bosch.
SOURCE: Can't cancel cycle without it starting
you have a few choices if the factory says that this is normal. try shutting off the breaker or unplugging the dishwasher. we use plugs when we install them to make removal easier. with the power down for a few moments, it may reset itself if its a solid state board. otherwise, let it run and then start it over again to do what you intended. its not a big problem if that is what you are stuck with for functionality. it is not a common need to reset, i would expect. check the manual too, you may need to hold the reset button for a few seconds or more.
good luck
mark
SOURCE: GE Triton dishwasher won't drain.
It sounds like the drain pump has gone bad.
First, unplug the unit or turn of the breaker, then remove as much water as you can with a wet vac if possible.
Remove the panels from the bottom of the front of the dishwasher (removing the big door won't help you) Then, disconnect the drain hoses from the pump (squeeze the hose clamps with pliers), any remaining water will come out when you do this, so you might want to put a thick towel underneath.
Pull out the wires—use pliers so you don't yank the wires out of the plugs, and remove the pump. Look inside and make sure there is nothing stopping the propeller- you may need to unscrew the pump from the plastic housing check.
If there is no blockage, it has likely just "gone bad" but to do one last check: take an old, two wire extention cord and carefully connect each wire to one of the prongs on the pump (make sure no stray wires "dangle" by using electrical tape if you need to) and plug it into a wall outlet.
If the propeller spins, something else is wrong with the machine but if it doesn't, you need a new one.
SOURCE: smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based. The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum. There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent. Use caution, the thicker the clog, the harder the pump has to work and it may fail. Hope this helps.
