Question about KitchenAid KSB5 Ultra Power Work Top Blender
What is the rubber clutch part number for model ksb50b4 and how do I install it?
  • 4,399 Answers
Hold on one second.
Posted on Feb 26, 2011
Anonymous
SOURCE:
I need the rubber washer for the ge blender 169004
try GE we do not have parts on FIXYA only advice
Aug 23, 2016 | GE Blenders
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
The buttons on my vita-mix vm0115e wont work. We have been loosing one button at a time. Was going to see if there was a loose cable or something, but I can figure out how to get the base off.
WE do not have your model here in NZ but this is how you get into our models
Remove square rubber base beaker locates onto. Remove motor driving clutch. Remove 4 screws under rubber pad you have just taken off.
Mar 28, 2014 | Vitamix Vita-Mix VM0115E 36021 Blending...
How do you replace a bad circuit in Kitchenaid blender KSB50B4
It is more likely the motor is faulty than the circuit board. Test the motor with a meter.
Aug 12, 2012 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
How do i remove the rubber clutch of my kitchenaid blender
Grab the blade with a rag so you don't cut yourself, then grab the clutch with another rag and turn CLOCKWISE. It's threaded reverse - took me hours to figure this out. I found grabbing with rags or maybe towels worked the best. That should work
Nov 22, 2009 | KitchenAid KSB5 Ultra Power Work Top...
Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Apr 01, 2009 | KitchenAid Blenders
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
KitchenAid KSB5 Ultra Power Work Top Blender Logo
372 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
ThaMp3Doctor
ThaMp3Doctor
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
