Sounds like the fans need cleaned or replaced. If the board and or the processor get to hot they may actually throw an error code. Try cleaning it and making sure the fans are moving.
Sound like you have a overheating problem. Your capacitors might have reached their end of life thus making them overheat quickly. Try to check if there is a fan inside your TV. If there is a fan, try to clean it see if that helps.
sounds like your motor maybe bad and shutting off becuz it is overheating.the noise could be the motor or a bearing or seals .depending on name brand and who u use may or may not be worth fixing motors are expensive to replace.
If it is the compressor making that sound,The compressor is bad.
A fan motor can as make this type of noise as well when going bad.
If it is the fan motor stopping,this will also shut the compressor down,due to the thermal overload protection.
There are two basic fans. One over your processor and one inyour power supply. When theiry are worn out they roar with vibration, especially when starting cold. Once they warm up they expand and quieten down. The best thing is to check and change a roaring fan, and also make sure it's not rubbing against wires, which also causes loud buzzing and roaring.
