MY KITCHENAIR MIXER KP26M1XR PROFESSIONAL WILL ONLY OPERATRE AT HIGH SPEED NO MATTER WHERE 1 PUT THE CONTROL BUTTON? WIFE HAS USED THE MIXER 10/15 TIMES BEFORE AND NEVER A PROBLEM
I have the same problem. replaced speed control board twice still same problemI have the same problem. replaced speed control board twice still same problem
You can't post conmments that contain an email address.
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from
Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from
the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now. 2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws. 3. Plug in your mixer and Set the speed selector to "Stir". 4. Turn each top screw One full turn couterclockwise (alternating between Left and Right) Keep making one full turn at the time (for both left and right) until the motor starts running. 5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your watch or clock and start counting the number of times the shaft touches your finger in 60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting again. Now tighten both lock nuts. 6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows: Stir speed - 60 Speed 2 - 95 Speed 4 - 135 Speed 6 - 180 Speed 8 - 225 Speed 10 - 280
I would recommend that you first check the Hall effect sensor which determines the speed. I had this exact problem and I actually went out and bought another Hall sensor for about $13. I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight. Guess what? My original sensor also made my mixer work! There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations. 1. Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. 2. You'll need a phillips head screwdriver to open up the mixer. 3. Make sure that the connection between the control board and sensor is absolutely tight and snug. 4. Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work. Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it. I actually found the right orientation through trial and error. By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work if it were reconnected with correct orientation. 5. This whole process probably takes less than 10-15 minutes to perform. 6. Make sure you use common sense and unplug the mixer when making connections and such.
Hi. All of you have the same problem. The electronic speed control board needs to be replaced. This board can be installed without much trouble. The board is modular, remove the old board and install the new one. The wiring is connected by a modular plug.
Goto www.kitchenaid.com enter your model # and search for the parts manual. These drawings will assist you with the task at hand.
If this solution has assisted you, please rate it. Good luck! ricardok45
First thing, check the Hall Effect Sensor (part # 9703312) to make sure that it is seated snugly AND properly! The Hall Effect sensor measures the speed of a tiny rotating magnet and basically tells your mixer how fast it should rotate. I was experiencing the same problem that many others have described here--my mixer would go really fast no matter what speed I put it on and it would shut off after five seconds. I came to the FixYa site and saw that one solution that seemed to work was to replace the Hall Effect sensor. So I went to a local hardware store and purchased a new Hall Effect Sensor for about $13. After I replaced the "defective" sensor, my mixer still did not work. So, I started experimenting with the three prong orientation of the control board--this can make a big difference. After a little trial and error, I found the correct orientation for the sensor and my mixer worked good as new! But I was curious to see if the improper orientation was the cause of my original "defective" sensor. So I put the "defective" sensor back with the proper orientation and THIS ALSO FIXED MY SPEED PROBLEM! There was nothing wrong with my original Hall Effect Sensor at all--it simply was not snugly or properly seated! I'm not sure how it happened--possibly over time the sensor prongs may have become unseated from the vibrations of running the mixer on high speeds--but my original Hall sensor was not seated properly or snugly. So before you run out and buy a new Hall Effect sensor make sure that the original one is not only snugly seated but also properly oriented! If I knew how to add digital pics, I would have put pictures in my comments to clearly demonstrate what I found. Unfortunately, I am not sure how to do this.
To sum this up:
1. Download the parts information and diagrams from the Kitchenaid site and find the Hall sensor (part # 9703312).
2. Make sure that the Hall sensor is firmly attached on both ends. The actual sensor should be located next to a tiny magnet and this end needs to be securely seated. And the other end of the Hall effect sensor has three small prong holes which also need to be firmly and corrected seated to the control board!
Bottom line, my mixer is working like new and I put the original Hall Effect sensor back in the mixer. I'm going to hold on the new one as a backup...you never know.
