The tv have a problems known as a convergence problems,it dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board will solved the tv convergence pictictue problems.The shop,will cost u like $300-350 for parts and labors.
Sounds like your TV has a convergence problem. You can get parts and repair instructions from http://www.TvRepairKits.com
SOURCE: Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
SOURCE: Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
SOURCE: blurry screen double vision picture
The convergence circuit has failed. It is not a easy fix due to the tear down needed to get to the circuit area. I would call Mitsubishi at 18003322119 to get a Authorized Service Facility to check it out and give you a estimate of repair cost.
SOURCE: double vision on t.v screen
Hi frank
To answer your question;
The problem with your tv is caused by the convergence circuit.
If you can`t adjust it anymore it means that some parts have gone bad in that circuit.
It is repairable and you or a friend can do it.
I`m going to leave you a couple of web addresses where you will find the parts and instructions on how to do it and also the tools you`ll need.
For the parts:http://www.tvrepairkits.com/xcart/home.php?cat=1662
For the tools(recommended) if you don`t have them already:
http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=e3fab1b8cee368315ca4bf73be5a2a83&keywords=sd1284&x=7&y=5
Hope this helps
Good luck
SOURCE: the image looks blurry, distorted almost like doub...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
CONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
