it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
may sound crazy, but sometimes the water pump gets clogged and does not operate, so will not spin. safety feature, I guess.
Try cleaning out pump.
Bruno
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
the pump is stuck. you need to get a pump replaced, a piece of dirt is all it takes to mess up the pump, exspecally if you are on well system, check the filter in the line and make sure its clean. if the machine is not spinning out, and its running the entire cycle the transmission is not engaging correctly, have this checked out.
let me know if you need further help
Thanks,
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
