Hello. I have an issue with the Hercules Dj Console 4-Mx. I try to use it with an Acer Aspire One mini laptop. Everything is working good. No cracks in the sound, smooth palyback. Now comes the bad part: When DECK A is playing and i try to cue the next track on DECK B i don't hear the tune in my headphones. Drivers are installed as i followed thru the manual. One thing i've noticed that if i acces the options menu of VDJ and at the Sound tab i select LINE as an input the sound starts to crack i can hear then the track in the headphone but it's a total ****. So to have a good and smooth playback and no cracks in the sound i have to select at the input to none. Where am i getting wrong PLSSS HELP.
The problem may not be your thermostat. The outdoor unit has a
refrigerant reversing valve that maybe the problem. This valve changes
position pending AC or Heating. The Aux on the thermostat energizes
when the outdoor air temp drops below a certain set point set up by the
installer or when the thermostat is set to it.
Was it working at first, and it just stopped? Try unhooking everything and just isolate the one cdj and plug it in see if it will eject. If its Brand New and this just started happening my sugguestion is to take it back to the store. you get what you pay for and numarks whole dj in a box line is the bottom line stuff.
With risk that warranty will be voided, you could open it and look for problems. Most of these have a speed control so if yours does, vary that to insure it is not near the real slow end of the range.
what do u mean it sounds like ****? it could be a dozen things cables loose wires, basically check n recheck everything n then just the dj stuff by itself
that will narrow it down so we know what it is.
Exactly the same thing happened to me think they send them out like it so you get the info fader upgrade I took out the two screws popped the fader out it was cruded up so I sprayed contact cleaner in to it.Just to clarify you have it set up right if your using it just with software you need the in on chan 2 out on chan 3 on the front and make sure the curve is set right
