Heating & Cooling Logo
Posted on Feb 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sunbeam dual control heated mattress pad cover just installed flashes F2 on either/both of the remote controls. Why, and what can I do about it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2009
Points
I have older sunbeam duel control matress pad. the control is simple with a dial that turnes for low or higher settings. it shows a red line that is small for low and gets thicker as the setting gets higher. there is a button for on and off. I set up the cover and turned on. the green on lite is flashing and there is no heat i do have it on high and it now will not turn off by the button.
Anonymous
Level 3:
President:
  • Master 1,489 Answers
  • Posted on Feb 22, 2011
Anonymous
Master
Level 3:
President:
Answers
1489
Questions
7
Helped
765717
Points
4966
Sunbeam heating pad model 828-511 is showing F2 on controller
Hello, Pat -
I can only find that the F2 error code means there is "a problem;" not what the problem is.
I suggest you go to this Sunbeam web page for your model of heating pad:
http://www.sunbeam.com/pain-relief/back-and-spine/sunbeam-microplush-body-shaped-heating-pad-with-digital-lcd-controller/000828-511-002.html
You should see a link for "Live Chat" on the right side of the page. Click or tap on "Live Chat" to text with a Sunbeam Customer Service Representative. He or she should be able to explain the F2 error code and what can be done to correct it.
Best wishes.
Sunbeam heated mattress pad blinking F2 on one side. How do I turn it off?
https://www.manualslib.com/manual/532253/Sunbeam-Sleep-Warm-Sleep-Well.html?page=12
I have a sunbeam two control mattress heated pad. One side works fine but the other will show a F error when put on preheat..
look for creeses in liquid lines. also check fualty wiring for voltage. switch power to pads if it heats look at power supply
2answers
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
One control works and not the other control
I have a Sunbeam electric blanket. One control is blinking F2. How do turn that off?
I have a Rest and Relieve Therapeutic King Heated Mattress Pad that I have lost the remote control for. where can I purchase a replacement remote?
You should try to contact the supplier of your mattress cover. If they have a website, you can check their website to check if they provide the separate remote for that particular mattress. Even if they don\'t, you can contact them asking the solution.
Jack
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
I have a king sized Sunbeam mattress pad and this morning one of the dual controls began blinking, won't stop, and we can't turn it off. I checked connections and all seems fine. Help!!
Maybe the machine of yours is broken sir and you need to bring it to a technician before it's too late.
tou can check this url to find any kind of mattress:
http://www.bestmattressreviews.com/
The controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
26helpful
4answers
Malfunction heating pad
Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
Top Sunbeam Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
