Pull out the detergent drawer, pressing the catch button in the rear of the drawer. There are a couple phillips screws through the panel around the drawer. Take those out. The display panel (including the entire plastic piece) is attached by plastic clips. Unsnap them by applying firm, controlled pressure along the top and sides of the plastic panel. Should come right out for you.
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Hello Phyllis Emmett - Do you notice any error codes displayed on the control panel or lights blinking? If so and the panel displays "DR", the door may have a defective door lock switch. However, if panel displays "DDO" either the drawer is not closing, magnet may be missing or have a defective reed switch, which you will need to contact a professional to diagnose the unit.
