carburetor or fuel filter is dirty. blow out the fuel filter and take carb bowl off and see if there is any debris in it if so you may need to clean the carburetor.
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
That is not a good situation. Too rich of a fuel adjustment can wash the bores out on that engine and prematurely wear it out! You will likely need to have the carburetor linkage and plate adjusted so that full throttle operates without engaging the choke. (If this is a single lever that you slide from slow, idle speed to fast, then on to choke)
To start up a cold engine requires reach mixture (air-gas).In your case it seems like the choke is not working ,so cold engine cannot start.If it is an injection operated system then it must have a temperature sensor which suppose to turn the choking on when cold engine needs to get started.Either the sensor is faulty or the choke or between the two there is a faulty connection somewhere.
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
