check inside the machine housing the part where the handle is moving but the rest of assembly is not it could be a pin has dropped out. use something like a nail etc to block this part so that the handle turns the assembly. until you can get a replacement.
if this is not the case then a part is broken and needs replacing.
see manual at this link.
https://manualsbrain.com/en/manuals/1275564/?page=61
see part pin PS-004-15 this could be the problem on pages regarding base and pedestal you can see the lifter assembly diagram here and a list of parts if replacements are needed.
also to reduce wear on this lifter ensure the bowl holding arms sliding rails are kept clean and lubricated. if they get fouled up with flour etc this over time, plus the weight of the bowl can cause excessive strain on the lifter assembly.
I hope this was helpful.
