If your Child Lock has been engaged you can unlock it by pressing and holding the FUNCTION key and pressing the MUTE key on your remote control. The only way to activate and deactivate the lock is with the remote control so ensure that you keep it in a safe place.
If you have lost the manual for your TV you can download a replacement at the following website:
http://www.retrevo.com/support/Apex-AT1302-TVs-manual/id/524ci552/t/2/
Thank you for the opportunity to assist you in resolving your issue.
Should you need further information or assistance please do not hesitate
to let us know.
hi,
To unlock your TV you must need the original remote of it. If you don't have then you have to purchase it. After the do the following for unlock you TV
Apex TVs have parental locks that allow you to block certain programs based on their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
1. Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
2. Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
3. Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
ok
